LittleBits
LittleBits Arduino
Art.nr: w6-Arduino
699 Kr
Lagerstatus: 35
Ej betygsatt ännu
You can now easily incorporate programming into your littleBits circuits! It?s everything you know and love about Arduino without the breadboarding, soldering or wiring. Simply plug into your computer, snap together needed modules, and program away!...
You can now easily incorporate programming into your littleBits circuits! It?s everything you know and love about Arduino without the breadboarding, soldering or wiring. Simply plug into your computer, snap together needed modules, and program away! You focus on the code, we'll cover the electronics.
  • Build with 10 getting started sketches, including Analog Pong, Tone Libraries and hundreds more from Arduino?s community!
  • Create code using the Arduino? programming environment
  • Communicate with software (Processing, MaxMSP, Flash etc?)
  • Connect modules with 3 inputs and 3 outputs using our bitSnap? magnetic connector as well as additional I/O for advanced hardware interaction
  • Access to community support from Arduino AND littleBits
Note: The Arduino At Heart module requires a power module to function [not included]. If you?re a littleBits newbie, we recommend the Arduino Starter Bundle to get started. If you already have a littleBits Kit, you?re all set!
Check out our Tips + Tricks for more ideas on using the Arduino module.
Circuit Diagram - PDF
  • Dimensions (mm): 20.0(H) x 77.0(W) x 149.0(D)
  • Product Weight: 0.02 lbs (0.01 kg)
  • Recommended Age: 14+
  • SKU: 650-0010
  • UPC: 810876020282
Omdömen (0)
    Bli först med att skriva ett!
