Pi Foundation
Dator Raspberry Pi 3 - Quad Core CPU, 1GB RAM, WiFi, BT
Art.nr: RPi3
395 Kr
Lagerstatus: 10
Ej betygsatt ännu
Jämförelse med Pi 2 samt prestandatester finns på bloggen!
Raspberry Pi 3 is here!
It is more power hungry than its predecessors, so we recommend a 5V/2.5A power supply!
Passande lådor hittar du här
Key features:
  • A 1.2GHz quad-core ARM Cortex-A53 CPU
  • Dual Core VideoCore IV® Multimedia Co-Processor. Provides Open GL ES 2.0, hardware-accelerated OpenVG, and 1080p30 H.264 high-profile decode. Capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and DMA infrastructure
  • 1GB LPDDR2 SDRAM
  • Broadcom BCM2837 1.2GMHz ARM Cortex-A53 QuadCore processor with VideoCore IV dual-core GPU
  • GPU provides Open GL ES 2.0, hardware-accelerated OpenVG, and 1080p30 H.264 high-profile decode
  • GPU is capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and DMA infrastructure
  • 1GB LPDDR2 SDRAM
  • HD 1080p video output
  • Composite video (PAL/NTSC) output
  • Stereo audio output
  • 10/100 BaseT RJ45 Ethernet socket
  • HDMI 1.3 & 1.4 video/audio socket
  • 3.5mm 4-pole audio/composite video out jack socket
  • 4 x USB 2.0 sockets
  • 15-way MPI CSI-2 connector for Raspberry Pi HD video camera (775-7731)
  • 15-way Display Serial Interface connector
  • MicroSD card socket
  • Boots from MicroSD card, running a new version of the Linux operating system (See Note below)
  • 40-pin header for GPIO and serial buses (compatible with Raspberry Pi 1 26-pin header)
Omdömen (0)
    Bli först med att skriva ett!
