-14%
Qubino
Inbyggnadsrelä 2 kanaler - Flush 2 Relay
Art.nr: ZMNHBD1
455:- 529:-
Lägsta pris de senaste 30-dagarna: 455 :-
Inbyggnadsmottagare - 2 kanaler som kan styras separat. Styr din inkopplade last via fjärrkontroll eller Z-Wave styrenhet, mäter även energiförbrukningen på ansluten last. kompatibel med Fibaro, Homey, Nexa, Telldus etc.
What is it used for?
The Qubino Flush 2 Relay is ideal for remotely controlling and switching electrical devices (e.g. lights or fans).
The smallest of them all.
The Qubino Flush 2 Relay module occupies a smaller volume than comparable modules of any other brand and will fit easily in any flush mounting box.
Energy wizard.
The Qubino Flush 2 Relay can measure the power consumption of the connected electrical device and itself has an extremely low power consumption of just 0.4 W.
Remarkably versatile.
The Qubino Flush 2 Relay can operate across a wide temperature range, from a chilly -10°C to a scorching 40°C (14°–104°F). It supports the connection of a digital temperature sensor, which is also useful for creating complex scenarios. Every module also acts as a repeater in order to improve the range and stability of the Z-Wave network.
The simplest installation.
Extremely small size and a specially designed casing mean that connecting the module inside a flush mounting box is simplicity itself. The installation process, tested and approved by professional electricians, consists of just three simple steps.
Incredibly fast support. Free.
We know that when you need information you need it quickly. That is why we offer a live customer service helpline, where you can get instant answers to all your questions. Free. All our support and training is personalized and free of charge.
The most tested and most reliable module.
Qubino modules are "install-and-forget" products. Our products are made to last, so we only select and use top-quality electronic components. Our modules are also the most tested Z-Wave microcontrollers on the market. The Slovenian Institute of Quality and Metrology (SIQ), an independent testing body, tests safety parameters including temperature rise, construction, insulation resistance, power consumption and overload in accordance with the EN 60669-2-1 standard.
4A fuses should be installed in series with the load according to the manual. Why this i necessary you can read about here.
Spänning: 24-30V DC
Spänning: 230V AC 50Hz
Mått(BxDxH): 41,8x36,8x16,9mm
Radioteknik: Z-Wave
Talks to Homey: Ja
Works with SmartThings: Ja
Kan anslutas utan nolla?: Nej
Potentialfri / Dry Contact: Nej
Talks to FutureHome: Ja
Min effekt (W): 0
Z-Wave 700: Nej
Max effekt (W): 920
Typ av montering: Inbyggnad
Qubino Flush 2 Relay Extended User Manual/Installation Manual
ProductGuideImage
Jämförelse Qubinos inbyggnadsmoduler
ProductGuideImage
Information: Säkringar till Qubinos produkter
Måste jag ha en säkring till Qubinos produkter? Vi informerar om vad som gäller
