Remotec
Z-Wave to IR Extender v 1.8
Art.nr: ZXT120
695 Kr 929 Kr
Lagerstatus: 39
Firmware version 1.8.
För information om vilka produkter som stödjs, se tillverkarens hemsida
The Remotec ZXT-120 is a Z-Wave to air-conditioner (AC) IR Extender, it works with any Z-Wave compliant gateway or portable controller by...
HA & Domoticz
Homey
Vera
ZNet Lite V1/V2
HG2
The Remotec ZXT-120 is a Z-Wave to air-conditioner (AC) IR Extender, it works with any Z-Wave compliant gateway or portable controller by translating Z-Wave?s Thermostat commands to AC IR control code. User can set the IR code from the built-in code library of ZXT-120 through the configuration commands, or use the learning function of ZXT-120 through the gateway user-interface (UI).
The ZXT-120 includes a built- in temperature sensor that enables remote monitoring of the room temperature via your home gateway, smart phone, or PC.
Technical Data
  • Z-Wave (868.42Mhz)
  • AC IR code library
  • Supports wide-range of carrier frequency (15 to 455kHz)
  • 5 directional IR emitters (hemispherical coverage)
  • 3.5mm jack for external wired IR emitter (optional)
  • Power: via USB, 5V DC Jack or 3x AAA batteries
  • Dimension:
    • Extender: 70mm (diameter) x 18mm (thickness)
    • Battery box: 70mm (diameter) x 15.5mm (thickness)
Utvalt från fyndhörnan
