- Specifikationer
Produktbeskrivning
When one of the buttons on the ZRC-90 is pushed, your Z-Wave central controller will receive a signal which it can use to trigger unlimited control possibilities. With 8 buttons, each supporting a long-press capability, you can control 16 different actions in your central controller. The ZRC-90 is a great solution for triggering events more quickly than taking out your smart-phone and running a home control app. The scene master is ideal for kids, elderlies and guests who may not have full access your to your smart home's mobile application. With a convenient snap-in wall mount, the ZRC-09 can also be removed to keep it handy while you go about your home for the ultimate in simple convenience.
Benefits
Benefits
- Works with any Z-Wave compliant gateway for easy scene activation
- Mount anywhere you like, or just put it on your coffee table (Wall mount is included)
- Easy access when your phone is not available
Central Scene-värden
De värden som skickas till controllern vid olika knappmanövrar är knappens nummer, följt av 000-003 beroende på hur knappen manövreras. Exempel:- Knapp 1 Enkelklick: 1000
- Knapp 1 Släpp upp: 1001
- Knapp 1 Håll in: 1002
- Knapp 1 Dubbelklick: 1003
- Knapp 8 Enkelklick: 8000
- Knapp 8 Släpp upp: 8001
- Knapp 8 Håll in: 8002
- Knapp 8 Dubbelklick: 8003
Specifikationer
- Z-Wave Plus compliant
- SDK version: 6.51.03
- 8 buttons can be single or double clicked to trigger 16 different actions from gateway
- USB upgradeable by special tool
- Powered by 2 x AAA batteries (not included)
- Battery life: 1 year at 30 button press per day
- Dimension : 110mm x 70mm x 13.5mm
- - See more at: https://www.zwaveproducts.com/shop/controllers/z-wave-scene-controllers/remotec-scene-master
| Z-Wave Plus: | Ja |
