Fibaro
The Button
Art.nr: FIBEFGPB-101-X-EU
499:-
FIBARO Button is a compact, battery-powered, Z-Wave Plus compatible device. It allows you to control devices through the Z-Wave network and run various scenes defined in FIBARO System. Different actions may be triggered with one to five clicks or...
FIBARO Button is a compact, battery-powered, Z-Wave Plus compatible device. It allows you to control devices through the Z-Wave network and run various scenes defined in FIBARO System. Different actions may be triggered with one to five clicks or by holding the button down. In panic mode, each press of the button results in triggering of the emergency scene. With its small design and wireless communication, the FIBARO Button can be conveniently mounted on any surface and in any position or location at home, e.g. beside the bed or under the desk.
FIBEFGPB-101-X-EU
Batteri ingår. Utbytesbatterier finns här.
  • Battery type: ER14250 1/2AA 3.6V
  • Battery life: est. 2 years (with default settings and max. 10 pushes per day)
  • Operating temperature: 0 - 40°C
  • Range: up to 50m outdoors, up to 40m indoors
  • Dimensions (diameter x height): 46 x 34 mm
Fibaro the Button User Manual
