Breadboard Full sized Solderless
Art.nr: 239_BB_WHITE
54:-
This is a 'full-size' breadboard, 830 tie points. Good for small and medium projects. It's 2.2" x 7" (5.5 cm x 17 cm) with a standard double-strip in the middle and two power rails on both sides. You can pull the power rails off easily to make the...
This is a 'full-size' breadboard, 830 tie points. Good for small and medium projects. It's 2.2" x 7" (5.5 cm x 17 cm) with a standard double-strip in the middle and two power rails on both sides. You can pull the power rails off easily to make the breadboard as thin as 1.4" (3.5cm). You can also "snap" these breadboards together either way to make longer and/or wider breadboards.
