-15%
PIR (motion) sensor - HC-SR501
Art.nr: HC-SR501
67:- 79:-
Lägsta pris de senaste 30-dagarna: 67 :-
Standard/Noname HC-SR501 based PIR sensor.
Adjustable sensitivity approx 3-7m Adjustable time delay approx 0,5-300 seconds. Operating voltage range: DC 4.5-20V Quiescent Current:
Please note: The jumper for setting trigger mode does not always exist. In that case there are solderingpads that can be used instead.
  • Adjustable sensitivity approx 3-7m
  • Adjustable time delay approx 0,5-300 seconds.
  • Operating voltage range: DC 4.5-20V
  • Quiescent Current: <50uA
  • Level output: High 3.3 V /Low 0V
  • Detection angel: 100 degree cone.
You can use the following tutorial for reference, but note that the pinout differs! PIR sensor tutorial page.
There's an excellent guide on how to easliy connect a PIR sensor to a Raspberry Pi!
Dimensions:
  • Length: 24.03mm/0.94in
  • Width: 32.34mm/1.27in
  • Screw hole distance: 28mm
  • Screw hole diameter: 2mm
  • Height (with lens): 24.66mm/0.97in
  • Weight: 5.87g/0.2oz
