• Stöd för Z-wave plus.
Vera
Vera Plus
Art.nr: VeraPlus-EU
1 595 Kr
Lagerstatus: 47
Kampanjpris!
The Vera Plus is a fully featured Z-Wave Plus compatible Internet gateway that enables you to keep connected to your home and business, no matter where you are.
It's compatible with an even wider range of devices that use ZigBee and...
It's compatible with an even wider range of devices that use ZigBee and Bluetooth wireless protocols, along with Z-Wave and Wi-Fi!
You can connect with more devices regardless of the type of wireless technology your device uses.
Your system can have over 200 devices on your Vera network, so VeraPlus is perfect for larger homes!
Vera Plus supports 1400+ devices from all major brands! Works with many popular devices using Wi-Fi, Z-Wave, ZigBee, or Bluetooth.
It has everything the popular VeraEdge has, including no monthly fees required!
Vera Plus adds more device compatibility, more memory, and more speed.
  • CPU: 880MHz MIPS SoC
  • Flash Memory: NAND 128MB
  • Memory: DDR3 256MB
  • Z-Wave: Z-Wave Plus
  • ZigBee: HA 1.2
  • Bluetooth: 4.0 + BLE
  • Wi-Fi: 802.11 a/b/g/n/ac
  • USB Port: USB 2.0
  • WAN Port: Gigabit Ethernet
Z-Wave plus: Ja
ProductGuideImage
Skapa en enkel scen på Vera
Så här skapas en enkel scen på Vera
