prisjakt m.nu på Prisjakt:
starrating
9.77 / 10
Läs våra omdömen
Trygg Ehandel
Kundkorgen är tom :(
Mätteknik för alla
Thermochrons
Större kvantiteter tas hem på 2-3 dagar! Kontakta info@m.nu för mer information.
The Thermochron family of iButtons are temperature data loggers which record and store time, temperature, and optional humidity for later analysis. The iButton's embedded computer chip integrates a globally unique address, a thermometer, a thermal history log, an alarm event log, and additional memory to store user data, such as location data or a shipping manifest. Thermochrons are recyclable, and under normal conditions, will log data for up to 10 years or 1 million temperature measurements. The following table is a comparison of the available Thermochron models:
Model Temperature Range Accuracy Resolution Values/Readings Logging Rate
DS1921G -40°C to +85°C ± 1°C: -30°C to +70°C
± 1.3°C outside this range
0.5°C 2048 1 to 255 min
DS1921H +15°C to +46°C ± 1°C 0.125°C 2048 1 to 255 min
DS1921Z -5°C to +26°C ± 1°C 0.125°C 2048 1 to 255 min
DS1922E 15°C to +140°C ±1.5°C: +110°C to +140°C /
±7°C typical: +15°C to +110°C
0.5°C - 8 bit /
0.0625°C - 11 bit
8192 - 8 bit /
4096 - 16 bit
1 sec to 273 hrs
DS1922L -40°C to +85°C ± 0.5°C: -10°C to +65°C 0.5°C - 8 bit /
0.0625°C - 11 bit
8192 - 8 bit /
4096 - 16 bit
1 sec to 273 hrs
DS1922T 0°C to +125°C ± 0.5°C: +20°C to +75°C 0.5°C - 8 bit /
0.0625°C - 11 bit
8192 - 8 bit /
4096 - 16 bit
1 sec to 273 hrs
DS1923- Hygrochron -20°C to +85°C
0 to 100% RH
0.0625°C - 11 bit
8192 - 8 bit /
4096 - 16 bit
1 sec to 273 hrs
    Art.nr.   Produktnamn+   Pris   Lager   Köp nu
DS1921G-F5 - Thermochron iButton -40°C till 85°C 2k datapunkter
 DS1921G   DS1921G-F5 - Thermochron iButton -40°C till 85°C 2k datapunkter  1+ 369,00Kr
10+ 339,00Kr
25+ 319,00Kr
50+ 269,00Kr
100+ 239,00Kr
 >50  Mer Info
DS1921H-F5 - Thermochron iButton +15°C till +45°C 2k datapunkter
 DS1921H   DS1921H-F5 - Thermochron iButton +15°C till +45°C 2k datapunkter  1+ 239,00Kr
10+ 219,00Kr
25+ 209,00Kr
50+ 189,00Kr
 10  Mer Info
DS1921Z-F5 - Thermochron iButton -5°C till +26°C 2k datapunkter
 DS1921Z   DS1921Z-F5 - Thermochron iButton -5°C till +26°C 2k datapunkter  1+ 239,00Kr
10+ 219,00Kr
25+ 209,00Kr
50+ 189,00Kr
 11  Mer Info
DS1922E-F5 - Thermochron iButton 15C thru +140C 8k datapunkter
 DS1922E   DS1922E-F5 - Thermochron iButton 15C thru +140C 8k datapunkter  1+ 849,00Kr
10+ 809,00Kr
25+ 769,00Kr
50+ 749,00Kr
 13  Mer Info
DS1922L-F5 thermochrons (high capacity) -40 to +85C 8k datapunkter
 DS1922L   DS1922L-F5 thermochrons (high capacity) -40 to +85C 8k datapunkter  1+ 695,00Kr
25+ 619,00Kr
100+ 419,00Kr
 20  Mer Info
DS1922T-F5 thermochrons (high capacity) 0 to +125C 8k datapunkter
 DS1922T   DS1922T-F5 thermochrons (high capacity) 0 to +125C 8k datapunkter  1+ 689,00Kr
10+ 649,00Kr
25+ 619,00Kr
50+ 499,00Kr
 5  Mer Info
DS1923-F5 - Hygrochron Temperature & Humidity iButton
 DS1923   DS1923-F5 - Hygrochron Temperature & Humidity iButton  1+ 1295,00Kr
10+ 1119,00Kr
25+ 995,00Kr
100+ 915,00Kr
 15  Mer Info
Visar 1 till 7 (av 7 produkter) Resultat Sidor:  1
© 2016 m punkt nu Sverige AB
