prisjakt m.nu på Prisjakt:
starrating
9.78 / 10
Läs våra omdömen
Trygg Ehandel
Kundkorgen är tom :(
Mätteknik för alla
Sensorer
Visa:
    Art.nr.   Produktnamn+   Pris   Lager   Köp nu
10K Precision Epoxy Thermistor - 3950 NTC
 372   10K Precision Epoxy Thermistor - 3950 NTC   49,00Kr   4  Köp
8" eTape Liquid Level Sensor + extras
 463   8" eTape Liquid Level Sensor + extras   495,00Kr   1  Köp
Adafruit BMP180 Barometric Pressure/Temperature/Altitude Sensor- 5V ready
 1603   Adafruit BMP180 Barometric Pressure/​Temperature/​Altitude Sensor- 5V ready   129,00Kr   13  Köp
Adafruit INA219 High Side DC Current Sensor Breakout - 26V +3.2A Max
 904   Adafruit INA219 High Side DC Current Sensor Breakout - 26V +3.2A Max   129,00Kr   8  Köp
Adafruit RGB Color Sensor with IR filter - TCS34725
 1334   Adafruit RGB Color Sensor with IR filter - TCS34725   99,00Kr   9  Köp
Adafruit TSL2561 digital luminosity / lux / light sensor
 439   Adafruit TSL2561 digital luminosity /​ lux /​ light sensor   79,00Kr   8  Köp
Adafruit TSL2591 High Dynamic Range Digital Light Sensor
 1980   Adafruit TSL2591 High Dynamic Range Digital Light Sensor   89,00Kr   9  Köp
Adafruit Ultimate GPS Breakout - 66 channel w/10 Hz updates - Version 3
 746   Adafruit Ultimate GPS Breakout - 66 channel w/​10 Hz updates - Version 3   495,00Kr   6  Köp
AM2315 - Encased I2C Temperature/Humidity Sensor
 1293   AM2315 - Encased I2C Temperature/​Humidity Sensor   359,00Kr   4  Köp
Conductive Rubber Cord Stretch Sensor + extras!
 519   Conductive Rubber Cord Stretch Sensor + extras!   119,00Kr   9  Köp
Contact-less Infrared Thermopile Sensor Breakout - TMP007
 2023   Contact-less Infrared Thermopile Sensor Breakout - TMP007   159,00Kr   6  Köp
DHT11 basic temperature-humidity sensor + extras
 386   DHT11 basic temperature-humidity sensor + extras   39,00Kr   29  Köp
DHT22 temperature-humidity sensor + extras
 385   DHT22 temperature-humidity sensor + extras   69,00Kr   >50  Köp
Extra strömsensor till Efergy 125A max
 efergyclamp125   Extra strömsensor till Efergy 125A max   109,00Kr   8  Köp
Extra strömsensor till Efergy 90A max
 efergyclamp90   Extra strömsensor till Efergy 90A max   89,00Kr   2  Köp
HC-SR04 Ultrasonic Sensor
 HC-SR04   HC-SR04 Ultrasonic Sensor   35,00Kr   >50  Köp
Heart Rate Educational Starter Pack with Polar Wireless Sensors
 1077   Heart Rate Educational Starter Pack with Polar Wireless Sensors   749,00Kr   1  Köp
Honeywell HIH4000-001
 HIH4000-001   Honeywell HIH4000-001   229,00Kr   1  Köp
Honeywell HIH4021-001
 HIH4021-001   Honeywell HIH4021-001   249,00Kr   4  Köp
IR Break Beam Sensor - 3mm LEDs
 2167   IR Break Beam Sensor - 3mm LEDs   35,00Kr   9  Köp
IR Distance Sensor - Includes Cable (100cm-500cm) - GP2Y0A710K0F
 1568   IR Distance Sensor - Includes Cable (100cm-500cm) - GP2Y0A710K0F   349,00Kr   6  Köp
IR distance sensor includes cable (10cm-80cm) - GP2Y0A21YK0F
 164   IR distance sensor includes cable (10cm-80cm) - GP2Y0A21YK0F   189,00Kr   4  Köp
IR distance sensor includes cable (20cm-150cm) - GP2Y0A02YK
 1031   IR distance sensor includes cable (20cm-150cm) - GP2Y0A02YK   199,00Kr   5  Köp
IR distance sensor includes cable (4cm-30cm) - GP2Y0A41SK0F
 GP2Y0A41SK0F   IR distance sensor includes cable (4cm-30cm) - GP2Y0A41SK0F   139,00Kr   11  Köp
IR sensor - TSOP38238
 157_TSOP38238   IR sensor - TSOP38238   19,00Kr   48  Köp
K30 Co2-mätare
 K30   K30 Co2-mätare  1+ 639,00Kr
5+ 575,00Kr
10+ 515,00Kr
 9  Mer Info
Leaf Wetness Sensor
 LWS   Leaf Wetness Sensor   39,00Kr   34  Köp
LED-Puls detektor
 LEDPULSE   LED-Puls detektor   279,00Kr   >50  Mer Info
Magnetic contact switch (door sensor)
 375   Magnetic contact switch (door sensor)   39,00Kr   35  Köp
MCP9808 High Accuracy I2C Temperature Sensor Breakout Board
 1782   MCP9808 High Accuracy I2C Temperature Sensor Breakout Board   65,00Kr   12  Köp
MPL115A2 - I2C Barometric Pressure/Temperature Sensor - Adafruit
 992   MPL115A2 - I2C Barometric Pressure/​Temperature Sensor - Adafruit   99,00Kr   10  Köp
Optical Dust Sensor - GP2Y1010AU0F inc cable
 GP2Y1010AU0F   Optical Dust Sensor - GP2Y1010AU0F inc cable   149,00Kr   4  Köp
Photo cell (CdS photoresistor)
 161   Photo cell (CdS photoresistor)   12,00Kr   27  Köp
PIR (motion) sensor + extras - Adafruit
 189   PIR (motion) sensor + extras - Adafruit   129,00Kr   15  Köp
PIR (motion) sensor - HC-SR501
 HC-SR501   PIR (motion) sensor - HC-SR501   55,00Kr   33  Köp
Pulse Sensor Amped
 1093   Pulse Sensor Amped   395,00Kr   2  Köp
Reflective IR Sensor with 470 and 10K Resistors
 2349   Reflective IR Sensor with 470 and 10K Resistors   29,00Kr   42  Köp
S8 CO2-mätare från SenseAir
 S8 004-0-0013   S8 CO2-mätare från SenseAir  1+ 639,00Kr
5+ 600,00Kr
10+ 569,00Kr
 3  Mer Info
SI1145 Digital UV Index / IR / Visible Light Sensor
 1777   SI1145 Digital UV Index /​ IR /​ Visible Light Sensor   129,00Kr   9  Köp
Soil Moisture & Temperature Sensor
 TEM01162B   Soil Moisture & Temperature Sensor   479,00Kr   5  Köp
Sound detection sensor
 ZC442900   Sound detection sensor   29,00Kr   13  Köp
Temperature Meter Panel -30 to +70 °C
 576   Temperature Meter Panel -30 to +70 °C   129,00Kr   21  Köp
Termoelement spetsgivare -50C till 1000C
 SONDE890   Termoelement spetsgivare -50C till 1000C   99,00Kr   13  Köp
Termoelement trådgivare -50C till 450C
 KA02   Termoelement trådgivare -50C till 450C   139,00Kr   14  Köp
Tilt ball switch
 173   Tilt ball switch   25,00Kr   10  Köp
TMP36 - Analog Temperature sensor
 165   TMP36 - Analog Temperature sensor   25,00Kr   5  Köp
TSL250R ljus till spänning
 TSL250R   TSL250R ljus till spänning   49,00Kr   18  Köp
TSL252R ljus till spänning
 TSL252R   TSL252R ljus till spänning   49,00Kr   27  Köp
VCNL4010 Proximity/Light sensor
 466   VCNL4010 Proximity/​Light sensor   89,00Kr   8  Köp
Volt Meter Mini 2-wire  (3.2 - 30 VDC)
 460   Volt Meter Mini 2-wire (3.2 - 30 VDC)   99,00Kr   8  Köp
Volt Meter Panel 2-wire  (4.5 - 30 VDC)
 575   Volt Meter Panel 2-wire (4.5 - 30 VDC)   99,00Kr   11  Köp
Visar 1 till 51 (av 51 produkter) Resultat Sidor:  1
© 2016 m punkt nu Sverige AB
