RFXCom
RFXtrx433E USB 433.92MHz Transceiver
Art.nr: 14103
995 Kr
Lagerstatus: 51
Omdömen (2)
New RFXtrx433E - Extended Version
The RFXrtx433E USB transceiver enables you to control 433MHz-based devices from your computer or from a Z-Wave controller such as the Vera3 or Vera Lite. It supports a huge number of 433MHz-based...
The RFXrtx433E USB transceiver enables you to control 433MHz-based devices from your computer or from a Z-Wave controller such as the Vera3 or Vera Lite. It supports a huge number of 433MHz-based products, including the LightwaveRF devices as well as Oregon Scientific, HomeEasy, Somfy...
The RFXrtx433E interfaces with a wide range of home automation software, including Domoticz, Homeseer, Indigo, Xtension, and hardware controllers such as the Vera Edge, Vera3 and Vera Lite.
RFXtrx433E - Extended capabilities This is the RFXtrx433E (Extended version) that replaces the previous RFXtrx433. It includes a hardware extension and additional firmware to enable it to support Somfy wireless blinds (RTS). The extedned functionality is already supported in Domoticzt, Homeseer and the VERA RFX plugin.
Omdömen (2)
5 2
  • Skrivet av: Lars
    Väldigt lättarbetad och lättanvänd, hade en Tellstick Duo innan men denna är mycket bättre! Rekommenderas!
  • Skrivet av: Hampus
    jag köpte denna för att koppla ihop den med min Veraplus, var riktigt smidigt med hjälp av denna guide: http://www.automatiserar.se/guide-installera-rfxtrx433e-pa-ui7-veraplus/ Det är precis så enkelt som det verkar och den gör sitt jobb strålande!
