MCO Home
Air Quality Monitor CO2
Art.nr: MH9-CO2-WD
1 799:-
Monitor CO2 concentration in air with high accuracy Power supply:12VDC (Not included) CO2 range: 0-2000ppm, default alarm threshold:1000ppm (adjustable) Temperature range:-9.0~50 ?; Humidity range:...
  • Monitor CO2 concentration in air with high accuracy
  • Power supply:12VDC (Not included)
  • CO2 range: 0-2000ppm, default alarm threshold:1000ppm (adjustable)
  • Temperature range:-9.0~50 ?; Humidity range: 0%~99%RH
  • Dimension: 90*130*28mm (3.5'' *5.1'' *1.1'')
  • Installation: Wall-mounted (Vertical), Hole Pitch:60mm or 82mm
  • Z-Wave frequency: 868.42MHz(EU) , 908.42MHz (US) or other frequency customized
Typ av sensorer: Co2 Koldioxid
Typ av sensorer: Luftfuktighet
Typ av sensorer: Temperatur
