PrivatFöretag  SEKEUR
Varor: 0 st, Totalt: 0,00Kr
Mätteknik för alla
 m.nu på Prisjakt:
starrating
9.75 / 10
Läs våra omdömen
Kategorier
Sensorer
Visa:
    Produktnamn+   Pris   Lager   Köp nu
 8" eTape Liquid Level Sensor + extras   8" eTape Liquid Level Sensor + extras   349,00Kr   6  Köp Nu
 Adafruit BMP085 Barometric Pressure/Temperature/Altitude Sensor- 5V ready   Adafruit BMP085 Barometric Pressure/Temperature/Altitude Sensor- 5V ready   89,00Kr   0
 Adafruit INA219 High Side DC Current Sensor Breakout - 26V ±3.2A Max   Adafruit INA219 High Side DC Current Sensor Breakout - 26V ±3.2A Max   89,00Kr   14  Köp Nu
 Adafruit RGB Color Sensor with IR filter - TCS34725   Adafruit RGB Color Sensor with IR filter - TCS34725   139,00Kr   10  Köp Nu
 Adafruit TSL2561 digital luminosity / lux / light sensor   Adafruit TSL2561 digital luminosity / lux / light sensor   79,00Kr   29  Köp Nu
 Adafruit Ultimate GPS Breakout - 66 channel w/10 Hz updates - Version 3   Adafruit Ultimate GPS Breakout - 66 channel w/10 Hz updates - Version 3   349,00Kr   18  Köp Nu
 DHT11 basic temperature-humidity sensor + extras   DHT11 basic temperature-humidity sensor + extras   39,00Kr   19  Köp Nu
 DHT22 temperature-humidity sensor + extras   DHT22 temperature-humidity sensor + extras   75,00Kr   7  Köp Nu
 Extra strömsensor till Efergy 90A max   Extra strömsensor till Efergy 90A max   89,00Kr   16  Köp Nu
 HC-SR04 Ultrasonic Sensor   HC-SR04 Ultrasonic Sensor   35,00Kr   >50  Köp Nu
 Honeywell HIH4000-001   Honeywell HIH4000-001   229,00Kr   2  Köp Nu
 Honeywell HIH4021-001   Honeywell HIH4021-001   249,00Kr   2  Köp Nu
 IR Distance Sensor - Includes Cable (100cm-500cm) - GP2Y0A710K0F   IR Distance Sensor - Includes Cable (100cm-500cm) - GP2Y0A710K0F   249,00Kr   12  Köp Nu
 IR distance sensor includes cable (10cm-80cm) - GP2Y0A21YK0F   IR distance sensor includes cable (10cm-80cm) - GP2Y0A21YK0F   149,00Kr   9  Köp Nu
 IR distance sensor includes cable (20cm-150cm) - GP2Y0A02YK   IR distance sensor includes cable (20cm-150cm) - GP2Y0A02YK   149,00Kr   10  Köp Nu
 IR sensor - TSOP38238   IR sensor - TSOP38238   19,00Kr   >50  Köp Nu
 K30 Co2-mätare   K30 Co2-mätare   Från 515,00Kr   10  Mer Info
 Leaf Wetness Sensor   Leaf Wetness Sensor   39,00Kr   1  Köp Nu
 LED-Puls detektor   LED-Puls detektor   399,00Kr   >50  Mer Info
 Liquid Flow Meter - Plastic 1/2" NPT Threaded   Liquid Flow Meter - Plastic 1/2" NPT Threaded   95,00Kr   15  Köp Nu
 Magnetic contact switch (door sensor)   Magnetic contact switch (door sensor)   39,00Kr   >50  Köp Nu
 Optical Dust Sensor - GP2Y1010AU0F inc cable   Optical Dust Sensor - GP2Y1010AU0F inc cable   149,00Kr   11  Köp Nu
 Photo cell (CdS photoresistor)   Photo cell (CdS photoresistor)   12,00Kr   47  Köp Nu
 PIR (motion) sensor + extras - Adafruit   PIR (motion) sensor + extras - Adafruit   99,00Kr   37  Köp Nu
 PIR (motion) sensor - HC-SR501   PIR (motion) sensor - HC-SR501   59,00Kr   10  Köp Nu
 S8 Co2-mätare från Sensair   S8 Co2-mätare från Sensair   Från 515,00Kr   0
 SI1145 Digital UV Index / IR / Visible Light Sensor   SI1145 Digital UV Index / IR / Visible Light Sensor   99,00Kr   9  Köp Nu
 Temperature Meter Panel -30 to +70 °C   Temperature Meter Panel -30 to +70 °C   89,00Kr   25  Köp Nu
 Termoelement spetsgivare -50°C till 1000°C   Termoelement spetsgivare -50°C till 1000°C   99,00Kr   9  Köp Nu
 Termoelement trådgivare -50°C till 450°C   Termoelement trådgivare -50°C till 450°C   119,00Kr   13  Köp Nu
 Tilt ball switch   Tilt ball switch   19,00Kr   12  Köp Nu
 TMP36 - Analog Temperature sensor   TMP36 - Analog Temperature sensor   25,00Kr   15  Köp Nu
 TSL250R ljus till spänning   TSL250R ljus till spänning   49,00Kr   14  Köp Nu
 TSL252R ljus till spänning   TSL252R ljus till spänning   49,00Kr   19  Köp Nu
 Volt Meter Mini 2-wire  (3.2 - 30 VDC)   Volt Meter Mini 2-wire (3.2 - 30 VDC)   69,00Kr   8  Köp Nu
 Volt Meter Panel 2-wire  (4.5 - 30 VDC)   Volt Meter Panel 2-wire (4.5 - 30 VDC)   69,00Kr   7  Köp Nu
 Watermark Soil Moisture Sensor   Watermark Soil Moisture Sensor   389,00Kr   3  Köp Nu
Visar 1 till 37 (av 37 produkter) Resultat Sidor:  1
Förväntad leveranstid är 1-3 arbetsdagar
Du har väl inte missat vår fyndhörna?
Copyright © 2014 m punkt nu Sverige AB
Mastercard Visa Posten DHL
Svea
