• Stöd för Z-wave plus.
Philio Tech
On/Off Socket
Art.nr: PAN11-1E
449 Kr
Lagerstatus: 35
Ej betygsatt ännu
The PAN11-1E is a Gen5/ZWave+ switch plug that capable of controlling any appliance.
It can switch all loads up to 3000 W (Resistive load 3000W, 1500W for incandescent load or 320W for fluorescent load). The device is IP 20 rated and can...
  • Tipsa en vän
HC2
HC Lite
HomeSeer
Razberry
Vera
Zipabox
ZNet Lite V1/V2
HG2
It can switch all loads up to 3000 W (Resistive load 3000W, 1500W for incandescent load or 320W for fluorescent load). The device is IP 20 rated and can therefore only be used in dry environments. Switching is controlled wirelessly using Z-Wave or locally applying a button. A red LED indicates the switching status.
Normally 2 devices can be used at the same time in a double Schuko outlet.
  • Adopt Z-Wave protocol to secure the success of wireless two way communication
  • Higher RF output power (+2.5dBm output power as compared to -2.5dBm 300 series Z-wave module) to enhance the communication range
  • Easy install
  • Very low electricity consumption, meet Europe year 2012 energy-related products requirement directive 2009/125/EC no. 1275/2008
  • Resistive load 3000W, 1500W for incandescent load or 320W for fluorescent load
  • Overload protection
  • Z-Wave V6.02
  • Z-Wave Certificated
  • LVD: EN 61058
  • R&TTE : EN 301489, EN 300200,
Mått(BxDxH): 57.7x94.5x76.6 mm
Min effekt (W): 0
Z-Wave plus: Ja
Max effekt (W): 3000
Spänning: 230V AC 50Hz
Typ av montering: Plugin
Omdömen (0)
    Bli först med att skriva ett!
