Nano USB to Bluetooth Dongle V4.0
Art.nr: BT-118 Lagerstatus: 13
Add Bluetooth capability to your computer super fast with a USB BT 4.0 adapter. This adapter is backwards compatible with v2.1 and earlier, but also supports the latest v4.0/Bluetooth Low Energy.
We've used this with great success on a...
Produktbeskrivning
We've used this with great success on a Windows 7 computer, installing as a 'generic' Bluetooth device, but we expect it to work just fine with any modern computer as this chipset is very common. So far we've tested it to communicate with Bluetooth data modules only.
Drivers for CSR Bluetooth modules are built into Windows XP/7/8 so you do not need to install any software or download anything: other bluetooth drivers or 'stacks' such as BlueSoleil are not as good as the Windows stack and will cause problems. Just plug it in and let windows auto-install the BT driver!
Installation on Raspberry Pi is quick and easy, and you can head over to ModMyPis Bluetooth on the Raspberry Pi Installation Guide to get the module working quick and easy.
Features:
Features:
- Bluetooth v4.0, backwards compatible with v2.1 and earlier
- Internal Red LED to show that the device is working correctly
- USB Interface
- Symbol rate : 3 Mbps
- Tested for compatibility with the Raspberry Pi
