• Stöd för Z-wave plus.
Aeotec
Multisensor 6
Art.nr: ZW100
649 Kr
Lagerstatus: 162
Batteries are not included, but can be bought here or here - you'll need two pieces.
Make Your Home 6x Intelligent With Aeon MultisensorAeon MultiSensor 6 is the smartest way to catch all the action happening in your home in real time. The beautifully...
HA & Domoticz
Homey
Vera
ZNet Lite V1/V2
Zipabox
Aeon Multisensor-- main
Aeon MultiSensor 6 is the smartest way to catch all the action happening in your home in real time. The beautifully designed device monitors movements, tracks ambient lighting, keeps a tab on indoor temperature and humidity, listens for seismic activity, and also protects your home from UV lighting.
The smart sensor has been designed to provide an integrated solution for staying connected with your home, even while you're at work or on a vacation. Aeon MultiSensor 6 can be configured to work with your Z-Wave controller to get real time updates and notifications about the activity in your home. Want to get alerts when someone enters your home, or want to get notified when there's an unexpected change in temperature? Aeon MultiSensor 6 makes tracking home activity in real-time possible.
The fifth generation of the multisensor device has some massive improvements, with the sensor now relaying signals faster and farther. It has also been calibrated for accurate environment monitoring and comes with specialized sensors sourced from leading companies in Switzerland and U.S
Aeon has also reduced the number of batteries required to power up the device to two, but the device now delivering 50% more battery life, with the average lifespan now extended to two years.
Weighing just under 75 gms, Aeon MultiSensor 6 is also one of the lightest sensors in the market that can be installed even with a double-sided tape. It's also 70% smaller than the previous version, which means it can fit into any home environment, without making its presence felt.
Aeon Multisensor-- Motion
Track Intruder Movements
With 5 metres range and a 120° field of view, MultiSensor 6 captures motion data and intelligently tracks every activity in your home. Use it to extend security in your home and monitor movements even while you’re away.
Monitor Indoor Temperature
MultiSensor 6 comes equipped with a calibrated sensor that can accurately measure temperature in the range of -10~50°C (14 to 122°F). It can also connect with Z-Wave smart gateway to intelligently control your home's heating.
Aeon Multisensor-- Temperature
Aeon Multisensor-- Infrared
Detect Ambient Lighting
MultiSensor 6's digital light sensor allows you to accurately detect the ambient lighting in your room. Intelligently configure your home automation system to open or close curtains, or control the installed lights and dimmers based on your home's illumination.
Check Moisture and Humidity
Keep a tab on the humidity levels and automatically configure your fans, air-conditioners or dehumidifiers to maintain the perfect environment in your home. Monitoring your home on such an infinitesimal level has never been so convenient.
Aeon Multisensor-- _Humidity
Aeon Multisensor-- _Vibration
Record Seismic Activity
MultiSensor 6 can report and detect event-based vibrations, including subtle seismic activity. The inbuilt vibration sensor also provides protection against external tampering and would notify you in case it's moved from its place of installation.
Protection from UV Radiation
The intelligently designed sensor can differentiate between UV lighting and ambient lighting. Configure it with your room’s shades, curtains and windows to protect your furniture from bleaching or use it to build a healthy indoor environment.
Aeon Multisensor-- UV sensor
Features
Aeon Multisensor-- 6 in 1 sensor
MultiSensor Device
MultiSensor 6 packs six sensors-- Motion, Temperature, Humidity, Light, Vibration and UV to deliver a complete smart home experience.
Aeon Multisensor-- Super Wireless
Extended Connectivity
MultiSensor 6 now comes with faster and better connectivity, with signals now reaching 50% further, up to 150 metres, and also 250% faster.
Aeon Multisensor-- Superior Quality
Advanced Sensors
Aeon has designed MultiSensor 6 using the world's best sensing technology, with special sensors sourced from Switzerland and U.S.
Aeon Multisensor-- Longer Life
Longer Battery Life
Forget changing your batteries. .
Aeon Multisensor-- Smaller
Smaller in Size
The new MultiSensor 6 has been reengineered to shrink 70% in size. The smart sensor monitors activity without making its presence felt.
Aeon Multisensor-- Battery Life
Lighter in Weight
MultiSensor 6 weighs just 74 gms, 50% lighter than its first generation. It can be installed anywhere, supported even by a double sided tape.
Aeon Multisensor-- Calibration
Superior Calibration
The inbuilt temperature, humidity, light and UV sensors can be manually calibrated to suit every environment and every room.
Aeon Multisensor-- Half Batteries
Number of Batteries
Aeon has reduced the number of batteries in MultiSensor 6 from four AAA to two CR123A, making the sensor lighter and more energy-efficient.
Aeon Multisensor-- Degree
Personalized Readings
MultiSensor 6 provides you the convenience to read the temperature as per your personal preferences. Fahrenheit or Celsius- you choose.
Aeon Multisensor-- Digital Light Sensor
MultiSensor 6 comes with a superior digital light sensor that's capable of sensing lighting between 0 lux to 30000 lux in real-time.
Aeon Multisensor-- Tamper Protection
Tamper Protection
MultiSensor 6 warns you on every attempt to tinker or remove the device, and keeps you in control at all times, while ensuring home safety.
Aeon Multisensor-- Secure Communication
For enhanced security, the smart MultiSensor 6 uses AES-128 bit data encryption to communicate with Z-Wave devices in your home.
Smart Accessories for Perfect Installation
Aeon Multisensor-- Mounting Arm
Mounting Arm
Designed for corner installations, the mounting arm allows you to rotate the MultiSensor by 360°.
Aeon Multisensor-- USB Cable
USB Cable
The 1.5 metre USB cable provides the option to power up the sensor through mains, replacement to batteries.
Aeon Multisensor-- Tape
Tape
Since Aeon MultiSensor 6 weighs just 74 grams, it can be installed even using a double sided 3M tape.
Z-Wave plus: Ja
Typ av sensorer: Ljus
Typ av sensorer: Luftfuktighet
Typ av sensorer: Rörelse
Typ av sensorer: Temperatur
Typ av sensorer: Vibration
Typ av sensorer: UV
