• Stöd för Z-wave plus.
Popp
KEYFOB-C mini 4 Button Remote Control - Popp
Art.nr: POPE009204
549 Kr
Lagerstatus: 4
You want to be in control of your smart home? With the KFOB-C remote control you can switch the lights, the heating and window blinds with only one touch of a button. Using the KFOB-C remote control is as simple as using your car key remote control...
HA & Domoticz
Homey
Vera
ZNet Lite V1/V2
WeBeHome
You want to be in control of your smart home? With the KFOB-C remote control you can switch the lights, the heating and window blinds with only one touch of a button. Using the KFOB-C remote control is as simple as using your car key remote control ? and it is equally small and compact and suits to your key ring. Furthermore the robust sliding cover prevents involuntary touches of the buttons.
The KFOB-C remote control could be used as primary controller and secondary controller as well. With the buttons 3 and 4 new Z-Wave devices can be added to the KFOB Controller. Equally you can remove devices from your Z-Wave network.
Due to primary controller function you can use the KFOB as standalone remote control as well without using any smart home gateway. Devices such as sockets, window blinds, dimmer, lights and electronic door locks can be switched by KFOB-C directly.
Once one device is added to KFOB remote control it checks the device type (switch, dimmer,?) and assigns the buttons with correct commands.
Of course you can also include the KFOB-C to an existing Z-Wave smart home network. Therewith you have the possibility to trigger predefined scenes such as the opening of the garage door with simultaneous switching on all lights in your garden by only one touch of a button. Or start the scenario ?Good night? which switches off al lights and electrical devices in your house with only one touch of a button when you go to bed.
Features:
  • Smooth and robust housing
  • Sliding cover prevents involuntary touches of the buttons
  • Supports Security/secure commands
  • Four buttons can be assigned free (as single buttons or button pairs)
  • Longer battery life due to optimized energy management
  • More than 2 years battery lifetime in normal use
Z-Wave plus: Ja
