PrivatFöretag  SEKEUR
Varor: 0 st, Totalt: 0,00Kr
Mätteknik för alla
 m.nu på Prisjakt:
starrating
9.75 / 10
Läs våra omdömen
Kategorier
Thermochrons
Större kvantiteter tas hem på 2-3 dagar! Kontakta info@m.nu för mer information.
The Thermochron family of iButtons are temperature data loggers which record and store time, temperature, and optional humidity for later analysis. The iButton's embedded computer chip integrates a globally unique address, a thermometer, a thermal history log, an alarm event log, and additional memory to store user data, such as location data or a shipping manifest. Thermochrons are recyclable, and under normal conditions, will log data for up to 10 years or 1 million temperature measurements. The following table is a comparison of the available Thermochron models:
Model Temperature Range Accuracy Resolution Values/Readings Logging Rate
DS1921G -40°C to +85°C ± 1°C: -30°C to +70°C
± 1.3°C outside this range
0.5°C 2048 1 to 255 min
DS1921H +15°C to +46°C ± 1°C 0.125°C 2048 1 to 255 min
DS1921Z -5°C to +26°C ± 1°C 0.125°C 2048 1 to 255 min
DS1922E 15°C to +140°C ±1.5°C: +110°C to +140°C /
±7°C typical: +15°C to +110°C
0.5°C - 8 bit /
0.0625°C - 11 bit
8192 - 8 bit /
4096 - 16 bit
1 sec to 273 hrs
DS1922L -40°C to +85°C ± 0.5°C: -10°C to +65°C 0.5°C - 8 bit /
0.0625°C - 11 bit
8192 - 8 bit /
4096 - 16 bit
1 sec to 273 hrs
DS1922T 0°C to +125°C ± 0.5°C: +20°C to +75°C 0.5°C - 8 bit /
0.0625°C - 11 bit
8192 - 8 bit /
4096 - 16 bit
1 sec to 273 hrs
DS1923- Hygrochron -20°C to +85°C
0 to 100% RH
0.0625°C - 11 bit
8192 - 8 bit /
4096 - 16 bit
1 sec to 273 hrs
    Produktnamn+   Pris   Lager   Köp nu
 DS1921G-F5# - Thermochron iButton -40°C till 85°C 2k datapunkter   DS1921G-F5# - Thermochron iButton -40°C till 85°C 2k datapunkter   Från 137,50Kr   >50  Mer Info
 DS1921H-F5# - Thermochron iButton +15°C till +45°C 2k datapunkter   DS1921H-F5# - Thermochron iButton +15°C till +45°C 2k datapunkter   Från 137,50Kr   15  Mer Info
 DS1921Z-F5# - Thermochron iButton -5°C till +26°C 2k datapunkter   DS1921Z-F5# - Thermochron iButton -5°C till +26°C 2k datapunkter   Från 137,50Kr   11  Mer Info
 DS1922E-F5# - Thermochron iButton 15°C thru +140°C 8k datapunkter   DS1922E-F5# - Thermochron iButton 15°C thru +140°C 8k datapunkter   Från 495,00Kr   15  Mer Info
 DS1922L-F5 thermochrons (high capacity) -40 to +85C 8k datapunkter   DS1922L-F5 thermochrons (high capacity) -40 to +85C 8k datapunkter   409,00Kr
REA 279,00Kr
 >100  Mer Info
 DS1922T-F5 thermochrons (high capacity) 0 to +125C 8k datapunkter   DS1922T-F5 thermochrons (high capacity) 0 to +125C 8k datapunkter   Från 399,00Kr   9  Mer Info
 DS1923-F5# - Hygrochron Temperature & Humidity iButton   DS1923-F5# - Hygrochron Temperature & Humidity iButton   Från 499,00Kr   28  Mer Info
Visar 1 till 7 (av 7 produkter) Resultat Sidor:  1
Förväntad leveranstid är 1-3 arbetsdagar
Du har väl inte missat vår fyndhörna?
Copyright © 2014 m punkt nu Sverige AB
Mastercard Visa Posten DHL
Svea
