GPS Antenna - External Active Antenna - 3-5V 28dB 5 Meter SMA
Art.nr: 960
203:-
239:-
Lägsta pris de senaste 30-dagarna: 203 :-
Bevaka Produkt
Bevaka produkt
Leveranstid:
Give your Ultimate GPS V3 a boost with this external active antenna. This GPS antenna draws about 10mA and will give you an additional 28 dB of gain. It's got a 5 meter long cable so it will easily reach wherever you need it to. The antenna is...
Produktbeskrivning
Give your Ultimate GPS V3 a boost with this external active antenna. This GPS antenna draws about 10mA and will give you an additional 28 dB of gain. It's got a 5 meter long cable so it will easily reach wherever you need it to. The antenna is magnetic so it will stick to the top of a car or truck (or any other steel structure)
Comes with a standard SMA connector on the end. If you want to connect to our Ultimate GPS V3 module, be sure to pick up a uFL to SMA adapter!
GPS not included.
GPS not included.
