Popp
Flow Stop gas/water shut-off controller
Art.nr: POPE009501
1 595 Kr
Lagerstatus: 0
Overflowing bathtubs, leaking washing machines or defects to gas and water pipelines ? damages can occur almost anywhere and cause immense costs. The POPP Flow Stop shutoff can prevent this ? thanks to Z-Wave.
Flow Stop is a motor...
HA & Domoticz
Homey
Vera
ZNet Lite V1/V2
Zipabox
Flow Stop is a motor operated shut-off controller for automatic flow stop of gas and water pipes. It is equipped with Z-Wave technology. This means it is particularly suitable for use in smart homes.
Even installation is child?s play. The POPP Flow Stop is delivered completely including valve control/motor, power supply, mounting and Quick Start Guide and is easy to assembly on the existing ball stop valve. In doing so, all usual pipe standards, including ½ " and ¾?, are possible. On this occasion no pipes must be dismantled or even water must be drained. That way the installation is normally done in 5-10 minutes.
The POPP Flow Stop is driven by a motor and closes the ball valve mechanically. Even though the Motor requires only 12 Volt (1A), it has a high power output as well as high torque, which reliably closes the ball valve in just 10 seconds. Also a manual closing of valve is easily possible in case of power failure ? thanks to the clutch release bearing.
Once the Flow Stop is added to a smart home gateway via Z-Wave, the stop valve can be operated via any PC, notebook, smartphone or tablet. Additionally, in the event of leaking gas or water the smart home gateway ? when combined with sensors ? is able to stop a further inflow automatically and thus protects against more extensive damage and further danger.
The POPP Flow Stop is a good piece of security for the intelligent home defending from nasty surprises and high costs due to gas and water damages.
12V 1A power adapter is included.
Z-Wave plus: Ja
