Fibaro
Fibaro Home Center Lite
Art.nr: FIB_HCLITE
Lagerstatus:
57
Leveranstid:
1-3 Vardagar
Home Center Lite
Fibaro Home Center Lite is a consumer electronics device used for home automation. This small sized (90x90x33 mm) gateway communicates and manages up to 230 devices wirelessly using Z-Wave.
The new Home Center...
Produktbeskrivning
Home Center Lite
The new Home Center Lite controller allows for even greater integration of home multimedia with the Fibaro System (in case multimedia devices are compatible with the system). Manage your TV, home cinema, Hi-Fi and others by the FIBARO App. Play with scenes and associations, change channels and adjust volume. Using Fibaro, you don?t need any other remote than your smart phone or tablet.
Thanks to the built in power management functionality, you can monitor the current energy consumption and the power consumption history while being able to spot the devices consuming the most of it. Detailed statistics are presented as clear charts, helping you compare numbers and estimate upcoming bills.
The Home Center Lite is equipped with a mighty, incredibly energy efficient Cortex A8 processor (720MHz).
Compared to the Fibaro Home Center 2 the Home Center Light supports no VoIP, no voice control and no scripting language for advanced scene control.
Skapa en enkel scen på Fibaro Home Center
Så här skapas en enkel scen på Fibaro Home Center
Fibaro Home Center Lite User Manual
