Pi Foundation
Dator Raspberry Pi 2 - Quad Core CPU and 1GB RAM
Art.nr: RPi2
359 Kr
Lagerstatus: 9
Ej betygsatt ännu
Key features: A 900MHz quad-core ARM Cortex-A7 CPU (~6x performance) 1GB LPDDR2 SDRAM (2x memory) Complete compatibility with Raspberry Pi 1 Because it has an ARMv7...
Key features:
  • A 900MHz quad-core ARM Cortex-A7 CPU (~6x performance)
  • 1GB LPDDR2 SDRAM (2x memory)
  • Complete compatibility with Raspberry Pi 1
  • Because it has an ARMv7 processor, it can run the full range of ARM GNU/Linux distributions, including Snappy Ubuntu Core, as well as Microsoft Windows 10.
Check out adafrutits comparison between the old and new Raspberry Pi!
  • Broadcom BCM2836 900MHz ARM Cortex-A7 quad-core processor with VideoCore IV dual-core GPU
  • GPU provides Open GL ES 2.0, hardware-accelerated OpenVG, and 1080p30 H.264 high-profile decode
  • GPU is capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and DMA infrastructure
  • 1GB LPDDR2 SDRAM
  • HD 1080p video output
  • Composite video (PAL/NTSC) output
  • Stereo audio output
  • 10/100 BaseT RJ45 Ethernet socket
  • HDMI 1.3 & 1.4 video/audio socket
  • 3.5mm 4-pole audio/composite video out jack socket
  • 4 x USB 2.0 sockets
  • 15-way MPI CSI-2 connector for Raspberry Pi HD video camera (775-7731)
  • 15-way Display Serial Interface connector
  • MicroSD card socket
  • Boots from MicroSD card, running a new version of the Linux operating system (See Note below)
  • 40-pin header for GPIO and serial buses (compatible with Raspberry Pi 1 26-pin header)
Omdömen (0)
    Bli först med att skriva ett!
