-14%
Breadboard Half-size Solderless
Art.nr: half_size_bb
42:- 49:-
Lägsta pris de senaste 30-dagarna: 42 :-
Fåtal i lager
This is a cute half size breadboard, good for small projects. It's 2.2" x 3.4" (5.5 cm x 8.5 cm) with a standard double-strip in the middle and two power rails on both sides. You can pull the power rails off easily to make the breadboard as thin as...
This is a cute half size breadboard, good for small projects. It's 5.5 cm x 8.2 cm with a standard double-strip in the middle and two power rails on both sides. You can pull the power rails off easily to make the breadboard as thin as 1.4" (3.5cm) and stick it onto an Arduino protoshield. You can also cut these in half with a saw to create 2 tiny breadboards, or "snap" these breadboards together either way to make longer and/or wider breadboards.
